I picked up a pcv valve from the parts store yesterday. When I got home I went to replace it in my 1997 altima, but I could not locate it under the hood. Is there one in this car. The part catolog calls for a fram #337. can you help?
thanks
SOMEBODY is going to tell you to do a search.
I'M going to tell you that you shouldn't bother to attempt to change the PVC valve unless you are convinced yours is bad. It is located underneath the intake manifold. You can see it when lying on you back, looking up past the oil filter. How easily you can get it off, on the other hand, is a different matter.
1 - 2 of 2 Posts
