1 - 16 of 16 Posts
Sit Down. Stand Up.
rawkus said:
you dont need no write up to change your oil. use a 9/16s to remove the drain plug from the oil pan. let it drip, remove filter, add new filter and dont forget to oil the outer part of the filter. screw back in the drain plug and add 4 1/2 quarts of oil..
Isn't the 4.5 quarts a misprint? I believe that 3.9 quarts was the correct amount.
cruiser
i just turn my wheels to the right and i get enough clearance to unscrew the filter with my right hand. no ramps needed.
Make sure you check that the old filter gasket came off when you removed the filter. and rub a little oil on the new one before you install it.
Sit Down. Stand Up.
Discussion Starter #13
DesiEGO said:
^What oil do you use for the outer part of the filter ???
I believe just regular oil - no grease.
Also, can you reuse the old oil drain plug gasket? Or must you replace it?
1 - 16 of 16 Posts
