1 - 6 of 6 Posts
Hi everyone. i recently replaced the shift solinoids in my trans. I had a bad feeling doing this and was right. It now doesn't go into any gear bit park. I'm now looking to replace the whole trans and cant figure out if it has a locking dif or not. Its an 02 with the B trans. Any input is appreciated.
Shift lock control assembly/module??..its behind the gear cluster..check ebay.. about $25 ..there is a bulletin on it.. i hsve a thread i started yrs ago here...
In the mean time, stick a screw driver in the little round hole and u can take it off park... there is a little cover on it that you need to remove...
I am experiencing a 2 to 5 seconds delay for it to engage on D, but only in the mornings.
Any comments would be gratefully appreciated.
Thanks
1 - 6 of 6 Posts
