1 - 4 of 4 Posts
My 01 nissan altima runs great, no problems.
though, in the summer when its hot outside or anytime really, if i press the ac button, slide it to cold, and turn on the blower to 2 or 3, it wont run the ac compressor immedialty. I can take maybe 30 seconds or ten minutes for the car to decide to run the compressor.
No the air is not cold until the ac compressor engages. once it engages the air will get down to the good 34 to 39 degrees F.
I just tested the car. In my drive way I started the car cold, waited 2 minutes, turned on the ac, blowers, on cold, and waited for the air to get cold with windows up. It tooks 8 minutes before the compressor to engage and blow cold air. I dont know if it is coincidence or not, but it engaged right as the engine got to median heat gauge.
Discussion Starter #2
edit - I tried using a paper clip as a fuse for the "air con" fuse in my engine compartment, it immediately worked. order a new relay from Autozone. plugged it in works GREAT!!!!
And how the new generation 'fixes' things. You test the fuse and then change the relay when the fuse shows to be bad. ????????
Good luck with those whacky land diagnostic skills in the future.
1 - 4 of 4 Posts
