The engine idles consistently at about 600 RPM. Tach is steady.
However, about 75% of the time, the idle FEELS rough. I can feel it in the steering wheel. It kind of feels like the car is idling at a higher number, like 1200, even though the tach continues to read 600. Another description might be that it feels like the engine is heavily modified. It "sounds" like it has a lot more power than it actually does if this makes any sense.
But some of the time, it will seem to settle down and be relatively smooth and quiet (for an engine with 106k miles on it).
I had a couple of mechanics look at it and both claim the motor mounts are shot. Neither put the car up on the lift. The first wanted about $1300 to replace all 4 mounts.
The second one tested the car on the road and then back at the garage, did a test with his assistant while I watched with the hood open where I could see the engine move significantly front and back as [I think] it was shifted in/out of gear. I was told this was confirmation of bad front/rear mounts. He wants $500-$600 to replace only the front/rear mounts if I purchase them.
I always like to purchase parts myself, so I said OK, I will purchase the mounts and pay this guy to do the install job for the replacement.
Now, when I sourced and purchased the front/rear mounts I saw that they have wires and a sensor. Which made me wonder if it might be possible that sensor might be bad or the wire disconnected and I don't actually need to replace the mounts?
How does the motor mount sensor in the front/rear mounts work? What does it do? What triggers it?
