61 - 72 of 72 Posts
Discussion Starter #61
well maybe some suspension hacks. I've read about your guy's upgraded suspension parts. That will be later.
Are the sway bars on a 3.5 bigger than a 2.5 sl?
Fronts are the same, except for the SE-R, rears are all different, one each for 2.5, 3.5 and SE-R.
Discussion Starter #64
This is the closest wiring diagram for my mirror that I could find everything seems to line up colors seem to be okay makes sense so the blue and the wire I believe are for the left hand outside mirror
100689
100688
Per your pic above:
Black w/Red strip - Battery
Yellow - Ignition/Acc
Black - GND
Later rmodels tied the Black/Red and Yellow together to ignition so the homelink stuff only worked when the car was powered...to prevent people breaking into your car and then opening your garage and stealing the better stuff ;)
Discussion Starter #67
Good advice with the power wires.
Will look at the mirrors on the max when I get to the yard.
100691
My next victims. Glass bead blasted. Self etching primer then some black paint. Will the funnever stop. Only thing about being furloughed is I have time to do this.
So when do you install the Mr Fusion?? :)
100693
Discussion Starter #70
Just as a side note,
There was just a few more parts that could have taken off the 06.
Just put back brakes on the 05 (The Sheared Keyway car) They were so rusted i had put new calipers and rotors, parking brake shoes. When bleeding the brakes the master went out. The voice in my head kept saying to pull the master off the 06.
100728
100729
I still think it better to have to buy a master cylinder every now and then...than admit to listening to the voices in your head :)
Discussion Starter #72
LOL, yes that's true. Went to the yard today and scored this(y)
100730
Being furloughed I didn't need to put any more money in this car right now. I bought everything else for the rear brakes.
61 - 72 of 72 Posts
