1 - 1 of 1 Posts
I need help !!! I recently put in a new battery and alternator in my 2004 Nissan Pathfinder , I sprayed air intake cleaner through the throttle body just to clean carbon buildups , after I sprayed cleaner through the throttle body I turned my car on . It started idling rough and misfiring instantly then cut off on me , it wouldn't crank back up until I found out I blew my ecm fuse . So I replaced that and car cranks up fine . But now the engine won't stop idling rough . It misfires and my cylinder 1 ignition coil keeps melting , I've changed all the ignition coils , spark plugs , and ignition coil connectors , I don't know what to do . The mechanic says he thinks it's my ecm and suggest I get a new one or repair the one I have , any help is appreciated !!!
1 - 1 of 1 Posts
