1 - 2 of 2 Posts
The radio from my Sentra works - but only on/off/volume button. All the other buttons don't work / seems to be stuck. Any idea on how I can reset/make the radio work?
I only have on station as option and I can't get it onto my aux cable mode because the button won't work. Thanks!
You may need to replace the faceplate of the radio unit...but since you'll be buying it used, the entire radio should only cost you $50...so just swap that in. Not a hard job, just need a screwdriver, some plastic trim pry tools and a little gumption. Have a look on eBay for your radio model or see a local wrecker.
1 - 2 of 2 Posts
