1 - 2 of 2 Posts
After a week of research I think I am closer to replacing my Bose speakers in my 2005 SE.
I promise to add all of this to the FAQ on this forum when I'm done.
Some questions:
1. I know the Bose speakers are at a lower impedance than most speakers (1 ohm vs 4 ohms). Anyone out there replace JUST their speakers when they've had the Bose stuff? Do the Bose speakers use a common ground or do they have two wires going back to the amp?
2. I may also replace the Bose Amp. Has anyone done this and kept the Bose headunit? If so, did you use the speaker level outputs into an amp or did you buy a speaker to line level converter? Did you reuse the power to the existing Bose amp or run a new power line?
Thanks much!
Dave
1 - 2 of 2 Posts
