1 - 1 of 1 Posts
Parts off of a 2008 Nissan Altima 2.5 Engine
Prices before shipping
1) 80,000 Mile "Made in Japan" Engine Block $100
2) Two Crankshafts One is $65 for the higher mileage one and $100 for the 80,000 mile one
3) A/C Compressor with 80K on it, $75
4) Starter $25
5) Complete Made in Japan cylinder head with camshafts and sprockets $150
6) Right side CV Axle Assembly $35
7) Two Water Pumps $20 each
8) Two Water Pump Coolant Tubes $15 each
9) 2 Upper Engine Oil Pans $75 each
10) Piston Rod Set $65
11) 80K mile Pistons and Rods $100
12) 2.5 Timing Cover $75
13) Lower 2.5 Main Block Casting $50
14) 2.5 Valve Cover $25
15) Alternator $25
17) Timing Parts $50
18) Crankshaft Gear $20
19) Engine Sump Tube $20
20) Engine Oil Pump $75
21) 2.5 Rod Set $65 with higher miles
22) Two Belt Tensioners $20 each
23) Have engine mounts (Price Varies)
24) Low Mileage Power Steering Pump
25) Two Flywheels (Flywheel) $65 each
26) Two Upper Thermostat Housing $25 each
27) Two Lower Thermostat Housing $15 each
28) Two Engine Oil Cooler with hoses $75 each
29) Fuel Injectors and rails (price varies)
30) Two upper intake manifold $65 each
31) Two Throttle Bodies $75 each
1 - 1 of 1 Posts
