Hello guys, my 2007 Nissan Versa Is Overheating due to my electrical fans not coming on when my car gets hot, assuming I might've gotten a bad "fan control module" or a failing water pump. Test all of my relays, replaced coolant temp switch (all new) and pulled a radiator fan from a junk yard, old fan and new fan both kick on (low and high)when I test them. My lower radiator hose does not get hot, my upper hose does get hot. Replaced my thermostat(located in thermostat housing) and water control valve(located in water pump housing) . Lower hose still does not get hot, water pump has yet to be replaced.
Other info; originally assumed I had an emmisions issue due to the fact my belt would come on I didn't think to look at my fan because they sound similar. So up til recently have I known it was a fan issue. I've replaced my fuel pump, crankshaft/camshaft sensors, air filter, evap canister, also. Battery also.has few miles on it. Lol. After connecting my obd 2 scanner to my vehicle all faults were clear everything seemed to pass just fine and read correct according to my obd 2 scanner.
