1 - 8 of 8 Posts
I need some help! I know this post is a little long but if you can please read and provide some guidance I will truly appreciate it. Thanks !
A few weeks ago I was driving and noticed my car getting stuck in the lower gears and at one point it struggled to take off. I made it home and left the car parked for a couple fo days. When I went start the car it would turn over and try to start but then ultimately wouldn't. At first I thought is was the battery but or the starter but it's getting plenty of electrical power. I plugged in a diagnostic computer and it gave me the P1778 code which is the stepper motor if I'm correct. I thought it weird that the car wouldn't start but some people said it may be an internal function of the vehicle computer not letting the car start.
I did some research on it and found that the stepper motor could be replaced. However, after dropping the transmission pan and draining the fluid I found that the step motor is not on the outside of the transmission. So now, I need to remove the valve body. Can it be removed while the transmission is still in the car? Can anyone provide any guidance or answers?
Thank you!
Yes it can be replaced while the transmission is still in the vehicle. The valve body has bolts to pull it out the pressure solenoid and stepper motor is on top of the valve body. Had the same code for stepper motor ive replaced it and the problem still occurs. Id recommend replacing the entire valve body like 157.99 on eBay thats the best route im taking myself.
Hi Kb1995,
Did getting the valve body off ebay and replacing it work? I replaced the stepper motor and am still having the shifting problems. I was thinking of replacing the whole valve body or just buying a solenoid replacement kit.
Hi Kb1995,
Sorry for the late reply. Most people have tried replacing the valve body and it has worked and some it hasnt worked. Ive tore into it and found out that the pulley system isnt working as it should anymore. From it not shifting and getting hot and whining it waa starving for fluid and overheating. I was quoted 2200 and at the very most 3000 for a whole entire transmission rebuild. I wont know a forsure pricing or exact cause of the issue until i actually get it into a shop and go from there but I will keep you updated as it goes on.
Idk much about Nissan transmissions. But I don't think that's going to fix your no start problem. I've had bad valve body's on other cars. They've started just fine but they couldn't move.
Discussion Starter #7
Yeah, I figured out what the no start problem was. The battery was no good...But I replaced the stepper motor and that didn't fix the shifting problems. So, I bought a whole new valve body but haven't put it on yet.
Discussion Starter #8
I hope it's not the pulley system with mine. The stepper motor didn't work. I bought a valve body but haven't replaced it yet. Now I'm worried that I've spent all this money and it won't work in the end.
1 - 8 of 8 Posts
