My 2008 two wheel drive 5.6 liter pathfinder oil pan has started weeping oil. The gasket and flange are dry, the oil starts about half way down the pan itself. The pan has corrosion on it, but no holes that I can see.
There is a cross member that is connected to the frame just behind the rear of the oil pan. The back of the pan is molded to clear the cross member and has about a half inch or so clearance above it.
I’m thinking of replacing the oil pan myself and would like to know if the cross member needs to be removed in order to get the pan off?
TIA
