1 - 2 of 2 Posts
So, picked up this car for my son last night. It seems the remote will lock and unlock all of the doors but the drivers side. If you click the lock unlock from driver or passenger doors all the locks lock but the physical drivers side. My plan is to open to door panel and confirm all the wires are plugged in properly. Any other things to check before I order an actuator for the drivers side? At this time he simply has to use the physical key or push the physical button on the inside handle to lock but the physical key must be used to unlock. Yes, the proximity lock and unlock work for all the doors besides the drivers side.
Discussion Starter #2
Well, pulled the door apart and the plug to the actuator was loose. Snapped into locking position and all working fine.
1 - 2 of 2 Posts
