1 - 3 of 3 Posts
I'm banging my head against the wall and hoping you can all help me. The A/C in my car either does not regularly blow cold air (even when set to 60) or it blows cool air in the back, but not in the front.
  • A/C set to on
  • A/C set to coldest temp (60)
  • Fuses have been checked by dealer
  • Coolant has been recharged or replaced
  • Massive out-of-warranty bill to replace the compressor
Any other suggestions? There are few things worse than having a car that's hot as heck inside, especially as it starts to get warmer and warmer.
This all started last year, spontaneously, and while there were periods were it may have improved here and there, I can't get it to cool. I've drive on the highway, turned the PTT on/off, toggled the A/C switch on/off.
Thanks for your help. I feel like I've got a lemon here.:frown
Did the a/c fluid replaced at dealership or some place else ! some places have only one machine in order to pruge & refil a/c fluids , if so , & if their machine s contaminated , your whole system will too & you ll need to change evrything in order for it not to be contaminated , hopefully it wont be your case .
Wonder if you have a leak in the system. Was it checked also !
1 - 3 of 3 Posts
