Charging problem on my car , brand new interstate battery and rebuilt alternator from a reputable shop that I showed me on the machine it was charging. I got into it and started checking it found that the yellow wire has 4.74 volts on it will charge around 14.05-14.15 volts will charge fine but turning on wipers,high beams it holds steady then all the sudden after 20 mins will drop to 13.15 volts with 2. 34 volts on the yellow wire. I found that the wire ends up in the fuse box in a quick plug checked it there had the same 2.34 volts . Does anyone have schematics on this car 2012 Nissan Altima 2.5 coupe
