Uh, VB parts are pretty much matched to the main body, not wise to go mixing and matching there.
Your code as well could easily be for hydraulic leakage in main operating parts and nothing like VB may touch it. So many do that and solenoids or steppers if CVT and common to not work well if it doesn't make things even worse.
No rocket science there, bad VB valves and their bores will show it if you look close. AND, there is usually a pressure adjustment on the VB as the pressure solenoid only adds an amount to that main adjustment, it can be boosted up by itself but you have to know where it is located on the VB.
You may get it running only to have increased wear then overwhelm what you have established to then bring trans down again in short order.
Luck, but be ready for it. Unusual to find small parts for VBs, generally the habit is to sell them complete.
