1 - 2 of 2 Posts
I recently changed the interior lights from stock bulbs to LEDs and while most lights are working as should. The driver side backseat map light doesn't work properly permanently. It turns on automatically when any door opens during the first half of the day. Then around 7pm until the next morning, it doesn't turn on automatically.
It always turns on manually though so it clearly does work. No blown fuse or burnt out lights because I've tried the stock bulbs and other LEDs to fix it. But it stays the same. It's like a weird automatic timer is set somehow. It works when it wants to.
Discussion Starter #2
So I figured out what's wrong with it. The button is sensitive and only works if the button is barely pushed. So in between modes (before it clicks) and that's the only time it syncs back up. So I need to figure out how to remove the assembly and fix it or order a new one
1 - 2 of 2 Posts
