Go with what the Nissan OEM parts website shows. The JA000 is for the 4th gen Altima.
Four washers per mounting bolt? Approximate diameter and thickness of the washers you used? I'm going to do this for my 14 Altima as it's noticeably annoying when it's below freezing. No issue above 45°F for some reason.I went with the 4 washer method and it is a big improvement. You will feel some vibration but only if you are trying to look for it. It is not as obvious as before when everyone in the car noticed it.
All you have to do is put 4 washers on both the bolts between the underbody and the part. You will get those for $2 at any Auto store. (Or go for new the part itself which is $35).
Problem solvedI went with the 4 washer method and it is a big improvement. You will feel some vibration but only if you are trying to look for it. It is not as obvious as before when everyone in the car noticed it.
