1 - 7 of 7 Posts
Hi All, Does anyone have experience in replacing the transmission filter on these CVT? any info on the torque specs would help a lot. Thanks
Discussion Starter · #2 ·
Update: I called a dealer nearby and they confirmed that there is a filter on the side of the CVT which is replaceable. They said they don't service this and it's not needed. Since my first transmission gave up just at 109k I now replace my tranny fluid at around 25k miles.
The filter cover mounting bolt specs:
7 N.m. (0.7 kg-m or 62 in-lb)
Service manual calls for a new filter and a new filter cover after disassembly.
Also apply CVT fluid to the filter cover during installation.
Sent from my iPhone using Tapatalk
Discussion Starter · #4 ·
Thank you AlphaBetaUser for your reply, is there another filter screen located just when you take off the transmission fluid pan? in total, there are 2 filters?
There is another filter called "Strainer Assy-Oil " inside the pan. Nissan Part No.: 31728-3XX0A . No. 7 in this picture:
You need to drop the pan in order to reach there:
102001
1 - 7 of 7 Posts
