1 - 5 of 5 Posts
Greetings to all you Finatics.
I pulled the step light cover from the LF and RF door and there's nothing there. No light, no connector no nothing. Can someone confirm is the connector even there, maybe behind the door? Or did they just not install Step lights on this base model.
Altima FTW
ASE Certified Master Technician & Advanced Level Specialist
Maybe pull off the door panel to get a better look, the connector may have fallen down into the door.
As said previously, try pulling the door panel off. Be careful with the small plastic cover behind the inside handle - I broke mine when pulling it off (manual says to replace when pulling door). I think you will find a harness for step lamp.
Thank you both for the reply. I am a lil nervous about taking the door off but I think i can handle it. Thanks for the warning @Slappy_K. I will update ya this weekend.
1 - 5 of 5 Posts
