1 - 2 of 2 Posts
I like my truck, it has done more than what I asked for but I had to contact a few times [email protected] to get things done.
The dealers have been hard to convince, most mechanics did not agree with my complaints, but Nissan has been pretty honest and covered my issues.
So if you encounter issues, and you are told that it is an "inherent characteristic of the vehicle" do not automatically agree with them.
It may take some hard discussion and convincing them is not fun.
Here is the list of issues I encountered in less than 2 years 15000 miles:
Landers McLarty Nissan Huntsville AL
11862 miles 01 of August 2018
Nissan agreed it was an issue and IT IS NOT inherent characteristic of the vehicle.
Nissan Replaced the Steering Shaft covered by warranty.
11625 miles 17 of July 2018
Steering Wheel off center again and clunking sound in column.
Realigned steering.
Noise an feeling is inherent characteristic of the vehicle no work performed at this time.
10640 miles 15 of May 2018
Fuel Filter Pump and Fuel Filter Housing replaced covered by warranty.
Replaced both fuel filters.
Tire Rotation and Brake Inspection.
8987 miles 4 of April 2018
Vehicle Towed Coolant Hose blew off because of Broken hose clamp. Replaced and refilled covered by warranty.
PC5110 Reprogram ECM covered by warranty.
6990 miles 10 of November 2017 Steering Wheel off center and Alignment added an Extra Caster Camber Kit.
Covered by warranty.
Newton Nissan Shelbyville Tennessee
5388 miles 3 of August 2017 Rotor Brake Overheating (NTB17-069a). Replaced rotor and pad kit. Covered by warranty.
5388 miles 3 of August 2017 Engine Light On but no error code. Reset the error codes. Covered by warranty.
5388 miles 3 of August 2017 Reloaded GPS after map could not display on screen, reloaded map on GPS. Covered by warranty.
Kline Nissan Mapplewood Minnesota
3221 miles 12 of July 2017 Antenna loose main bolt missing from factory, added the main bolt. Covered by warranty.
Discussion Starter #2
Engine light On 18 of September 2019 at 17309 miles.
Brought the vehicle to Landers McLarty Nissan Huntsville Alabama.
Checked error code: Code P208C
Reductant Pump A, DAIG replace DEF supply pump assembly.
Landers McLarty Nissan ordered the part.
27 of September 2019 brought the vehicle to replace the DEF supply pump assembly.
1 - 2 of 2 Posts
