I recently replaced my 2019 Nissan Maximas head unit along with the Factory Bose system and Amp. The next step is to connect my stock 360 camera to the head unit. With that being said, does anyone by change have the color code/pin numbers of the camera positive and negative signal wires so I can create a harness for this connection. I've already located the 12v Reverse wire which is located in the 20 pin harness. I'm now looking for the signal wires and 6v camera wire within the 40 pin harness. I've already have a 12v to 6 volt converter, I just need the location of these wires. Thank you very much.
