1 - 12 of 12 Posts
Hi folks -
I just purchased a 2019 Nissan Fog Lights and I wanted to install fog lights. I noticed that the wiring harness for the fog lights are taped up behind the bumper but Nissan does not sell or provide the fog lights for the SR model. The guy at the parts counter said I could buy all the stuff separately and wire them in but I am wondering if there is a way to use the wiring harness. I didnt know if maybe connecting the lights and putting the new light switch in with the fog light switch would make it work.
I appreciate any advice anyone may have.
Best,
JR.
The fog lights for the SR are sold by Nissan Parts Warehouse, but they deactivate the DRL :(
Help me understand. By deactivate, you mean permanently, or just that the DRL function of the low-beams is switched off when the fogs are switched on by the IPDM? If the latter, you should be able to come up with some 'external relay logic' to override that ;)
Please clarify because my friend with an SR has already done the Fog Light add-on and his DRL's work just fine. The wiring harness for the Fog Lights is completely separate from the headlights and has no effect on the DRLs.
So I just bought a CPO 2019 Altima SR for a daily. Obviously it doesn't have fog lights.. I found some l.e.d DRL's & fog lights on ebay that I would like to buy and install. Three questions:
*Can you install them by way of plug and play?
*Has anyone in here actually installed either OEM or aftermarket fog lights in their SR?
*Is there existing harnesses to DIY wire them in?
Thanks in advance!
I'm trying to figure out how to wire up the aftermarket LED foglight I bought also. I know someone has figured this out.
inside my bumper it has the foglight plugs already. DR side is a green and grey wire and the pass side is a white and black wire.
1 - 12 of 12 Posts
