1 - 20 of 70 Posts
Hotshot Performance is looking someone to volunteer their car so HS can prototype the headers on. Volunteer would get a free set. Contant them if interested.
someone do this! Stillen stuff sucks! HS always made better stuff with LOTS more HP!! just look at the QR25 and SR20 headers!
We represent the east coast! anyone who is close do it!! you might be without your car for a few days, but free headers!! :eek: Im sure they will install them too!!!
only the 3.5 motor?
Discussion Starter #8
Hotshot Performance
1418 Arrow Hwy.
Irwindale, CA 91706
Tel: (626) 303-0076
Fax: (626) 303-1146
i got one.... what's u guys opinion on h.s. i dont know too much about them.... can someone fill me in on their history? i might be interested... need to do a background check....
Somebody tell H.S to make the 3.5 headers smog and emission legal.
Shift_This
Don't go knocking Hot Shot, my friend has one on his SpecV and it's a great mod. Great sound, respectable power, and looks good. And unfortuantly it's not smog legal it elimanates the cats. He did get a custom pipe made from Stromung so that the SAS light would not come on. The only problem he had with the header was that one of the bolts didn't line up perfectly.
And I'm looking for any options other than $tealin. He's a rip off and a bullshit artist. Somebody voulnteer their car. I wish I was out on the West Coast so I could.
I'm his friend, and I have the hotshot header. Marc was close in his explanation, but here's the details.
The first cat was eliminated (primaries from the stock manifold are welded to it, no choice)
The header did bolt right up, but one of the welds on the first primary was a little out of sorts, so the stock manifold nut needed to be ground down a bit for clearance. That took all of 5 minutes.
The pipe I got from Stromung is just their catback midpipe, with a resonator and o2 sensor bung welded in. The second cat is still on the car, right in front of the midpipe. You just take the secondary o2 sensor, lengthen the wires, and install it under the car.
All in all, it was a great buy at $390 to my door. Gains were great.
I did need the resonator as alot of guys with the stromung cat back and hotshot header complained about it sounding like a chain saw without the resonator. It sounds great now. Hotshot is a great company. You guys should try and get a set made.
Parts & Service Manager
I think that if you are worried about smog issues, then you don't want a header, because to make a good enought gain the pre-cats would have to be removed. Go another route for power. I want no cats, and I don't care about smog.
Life, Liberty, Pursuit of
I will be the hotshot header prototype
the fitting up of the prototype headers will be done between 3/13 and 3/19 at Hot Shot. My car will be there for two weeks.
I will let you know more as it develops
CARB!? Wee don' need no stinkin' carbs, we gots fuel injekshun!
Oh, yeah I live up here in conservative northern arizona, where people still wear guns on their hips and nobody cares about smog.
The Pre-cats are there just to help out with cold start emissions.
That's why their so close to the exhaust ports. The idea is that they'll light off quickly and burn off a lot of the Hydro Carbons tyat would otherwise get by the main cat befreo it could light off.
You can still pass with out them, you just need to make sure your car is at normal operating temperature when you car is smogged.
1 - 20 of 70 Posts
