1 - 7 of 7 Posts
do i have to do some adjustment in order to fit them in the door?
you get more bass from those than 5x7 so thats why i wanna use those there.
thanks yall
<for hire>
Search my friend, seach.
I just put 6.5's in my front last weekend. They will use the same screw holes as stock, but you will need to use a dremel or similar tool to modify the mounts to allow the speaker to fit.
that won't work for all 6.5" though. It all hinges on the mounting depth...and also whether or not it's an oversized 6.5". I just installed my cdt components a couple weekends ago and had to deal with both those factors. All I did was make a .5" thick mounting baffle out of mdf, but then I still had to dremmel out the original mounting ring because the basket still didn't quite clear it. Then after that I realized that the door panel wouldn't fit with that .5" of wood because it's slightly angled.
Oh well though, it was so close that I screwed down 2 of the 3 screws at the bottom, then the last screw I bypassed the map pocket and just screwed in the main panel. So far it works like a champ, and without rattles or interfering with the door closing, so I couldn't be happier.
1 - 7 of 7 Posts
