1 - 3 of 3 Posts
I just purchased a 2011 maxima that i really like but the very next day my AC quit blowing cold all of a sudden. I replaced the 10 watt with a 25 watt fuse and it still blew within minutes. Can there be anything else I can do before I replace the compressor and clutch??!! Is the clutch causing it to blow? I don’t get it. Please help!
Change the a/c relay unless it is part of the IPSM, past that the clutch is likely dead, a short that still works it can do that.
Amps not watts, two wildly different things.
After the fuses started blowing the battery wouldn’t charge and I was having problems with the power steering bc it would leak out within 30 minutes of filling. Well I just took it back to the lot and the damn serpentine belt wasn’t on it. Wtf. Explains the AC and the battery not charging and even problems with the power steering but not the leak. Shit.
1 - 3 of 3 Posts
