1 - 16 of 16 Posts
Civic Driver
hey guys, maybe you can help me w/ this.
on the freeway today, i started having this problem with my acceleration capabilities. Basically, i'm putting the gas pedal to the FLOOR and i can't seem to get above 2500 RPM. It's like there's basically nothing there. Car still runs, but not like she used to. only 84k on her so i'm not sure what the problem is. Any ideas on what this could possibly be? :confused:
missing El Polo Loco...
mass air flow sensor could be disconnected/loose. check connection. Without it the engine won't be able to rev past 3000 (neutral). no code from the ECM? Otherwise could be a faulty mass air sensor as well (vibration related).
Senior Member
Yep I had the same thing happen. I just unbolted the sensor. Wiped off the underside with a rag. Reinstalled it. Then reset the computer by disconneting the battery for a couple of minutes. Rehooked up the battery, and the car ran fine.
Civic Driver
Discussion Starter #15
thanks for all the help. it was the mass air flow sensor, just got a little loose i guess, did what you said, etc, and it runs fine now. thanks guys. :D
1 - 16 of 16 Posts
