I couldn't really find any info on how to add fog lights to a 2019 Altima SR. Took some time researching and talking to the dealer to figure out what was needed. Just finished the install and wanted to share the parts I used.
1) LED 2019, 2020 Altima L&R aftermarket fog lights from eBay. $66.00 (OEM are $229.00 each)
2) OEM Nissan L&R foglight bezels 62256-6CA0B, 62257-6CA0B $79.62
I wanted OEM for fit and they're painted black, eBay ones look just to be bare plastic.
3) OEM Nissan Switch Assembly that has fog light switch 25560-6CA2C $99.92
4) Nissan U-nut spring 01241-0001X, fog lamp screw 08566-6205A you need 4 of each of these to mount the
fog lights $11.35
All OEM parts were purchased online. I shopped around till I found the best prices shipped.
The plugs for the fog lights are already inside the bumper. Once you install the new switch assembly they have power and it works as if it was from the factory that way. I disconnected the battery and waited 30 minutes before I started anything.
I removed the 3 Phillips screws hold the plastic cover around the column on. Then I removed the air bag after learning how in the following link
, then the steering wheel (using a T50 torx it doesn't require a puller you do have to man handle it a bit and it will come off. When its almost all the way off go easy so when it does finally come loose you don't snatch the clock spring with it as I did), then remove the clock spring, then remove the angle sensor. Now you can finally remove and replace the switch assembly. I took plenty of time with every step as I'm far from a expert. I just did a lot of research. Removing all this was new to me as in our older Altima the switch assembly came off without having to remove anything except the plastic cover.
fog lights $11.35
