1 - 13 of 13 Posts
member
i tried to connect the indiglos again, they still dont light up. i touched a wire to the dimmer switch control and now all of my lights on my dash dont work, the speedo, the heat-cool controls, gear shifter, what do i need to fix it? cuz i cant drive at night.
Possible answer
It should be a fuse. If not you may have fryed the inside of the dimmer button. If thats the case you can get another one @ a junkyard for little or nothing. You may need to check all the fuses having to do with lighting!!
member
Discussion Starter · #7 ·
95-xe, your right, the tail lights and front corner bulbs are not working, i changed the fuse inside the engine bay, that read "tail light" now my tails and corners are working. but my dash will still not light up, this sucks cuz i am going out tonight!
member
Discussion Starter · #9 ·
did you turn up the dimmer? Maybe you rolled it down by accident
thats exactly what i did, my bad. everything is workin fine now, thank you so much for the help 95-xe.
now if i can only get the ****in indiglos to glow! they blow.
had them workin for 5 months then they stopped. they come on once in a while.
Alty Go Boom
might be a bad ground that can cause them to light on and off sometimes try regrounding them
check the dash lighting dimmer control.
1 - 13 of 13 Posts
