1 - 5 of 5 Posts
My key fob was not getting recognized by the car so I took it to the dealer and then they said the BCM module is faulty because water caused a short circuit and to fix it they will charge 600 dollars for the new part and labour.
So can I put a used bcm and reprogram both the BCM and the key?
Sam, you could source and install a used BCM yourself, but you'd still need either the dealer or a mobile locksmith to do the reprogramming of the keys...as the car will likely not start once the current BCM is removed. If you can get the matching keyfob with the used BCM this may negate the need for reprogramming.
Have
1 - 5 of 5 Posts
