1 - 8 of 8 Posts
Just Chillin'
I'm looking to add another amp. I have a 4-guage existing wire hooked up to my battery.
What are the differences between these 2 distrubtion blocks besides the number of outputs?
http://www.crutchfield.com/cgi-bin/S-057X6I0aqcf/ProdView.asp?s=0&c=11&g=715&I=211DB448&o=m&a=0&cc=01
and
http://www.ikesound.com/Prod_Details.asp?Prod_Id=1124
I would like to order from IKe instead of crutchfield. Is there something better at Ike i'm not seeing? Also, is this all that I need to add another amp?
Thanks.
JDM NCP31 & CZ4A
the 2nd one is fine so long as you run a fuse with both lines, most amp kits come with one anyways
its actually easier if u mounted it to the side of your battery though
krazie662 said:
Thanks for all of the help everyone. Would this one be good?
http://www.knukonceptz.com/detail.asp?product_id=FB1428
for the positive
and
http://www.knukonceptz.com/detail.asp?product_id=PB1448
for the negative
That covers the fuse also right?
Thanks again for the replies.
Actually the fuses aren't included with that distro block but you can pick up the fuses from knukonceptz.com also for less than $1 each...get 2 of the 60 A agu fuses and you should be set.
Just Chillin'
Discussion Starter #8
I know :angry4: I just realised after ordering...
1 - 8 of 8 Posts
