1 - 1 of 1 Posts
Per Topnotch till I die, who is the one who successfully switched from an automatic transmission to a manual one:
i only spent about 1800 and i bought alot of extra shit that wasn't needed. only should have been about 1500 or so. you will need:
clutch
clutch pedal
clutch master cylinder
hydraulic lines from master cylinder to slave cylinder
manual tranny
manaul axles
shifter linkage
shifter
shifter holder
rear motor mount bracket
manual ecu
**** make sure the counterweight is cut off the frame of the car after the conversion****
optional parts include:
clutch neutral safety switch
clutch start switch
manual wire harness
parts from auto that work in manual include:
starter
tps sensor
flywheel
flywheel retaining bolts
1 - 1 of 1 Posts
