Automatic Transmission change: drain & refill 2-3 times VS drop the pan and stuffs??
Hi folk, I have a White Nissan Altima 06 on 2.5 litres engine 4 speed at 55k miles. Everything looks ok and it is time change transmission fluid which never done before.I want to change ATF oil myself with Amsoil and I already bough it today. I don't like the idea of flushing the oil and I like to do it like drain and refill. I read another post http://www.nissanclub.com/forums/200...in-refill.html . It gave me a guideline on draining the old ATF oil from the drain plug and refilling the new one on the dipstick tube. I plan to do it 2-3 times to make sure it get almost 90-100% new.
However, today when I bough the AMSOIL from the dealer, he said I would waste the oil and money just doing drain and refill. He told me if I do like that the new will mix up with the old oil and it will use up the new oil so fast. He recommended me to go the shop to do the proper way by droping the pan, cleaning the gasket, changing the filter, and draning the oil out from the cooling line and from the torque converter. He said it was the best way to do it to make sure it get the new one in with 10 qts.. Ummm. I think I can't do it myself with all these stuffs. Only the labor cost is a lot too at least 100 bucks up and I still have to pay for amsoil almost $90 for 10 qts. That is pricey. Do you think it will be bad if I just do only drain and refill at 2-3 times? Also, I have another Nissan Sentra with automatic transmission 4 speed at 140 k miles. It is time to change the ATF as well. Can I do it the same way with drain and refill or I should take to the shop to do the big labor cost taking care the whole fluid line?
