1 - 14 of 14 Posts
· Registered
Hey everyone, what's the best spark plugs to use w/a 55 wet shot? I heard to use iridium plugs, but I'm not sure which brand. And what should it be gapped at, considering I don't have an ignition upgrade.
· Die Trying
depends on what system you're runnin. The JWT set up programed to use the stock copper plugs at stock setting. Or even plats at stock settong
but any other set up, copper NGK stock plugs at a lower gap, like .35 or something
· Die Trying
osama said:
just get the damn better plugs and ignition system or you'll end up with a blown engine
i thought you're not supposed to run an ignition system with nitrous? Isn't it too much spark
Rick, if you're reffering to the comment i made, you're right. But with the JWT set up, it's programmed to run any plug, at stock setting. But of course, i'm straight up STOCK, NGK copper
· Registered
Discussion Starter · #7 ·
I have a 1st gen and I'm getting the NX kit. It says not to use platinum, and NGK doesn't make iridiums for our car, at least their website didn't turn up any results. Also, I can't seem to find the NOS brand anywhere. anymore suggestions, about the ignition too...
· donor cycle
reread your post, i didn't want people thinkin they could use platinums with their regular setup.. but had i fully read it i would have realized you already said that :)
· 350Z
If you get ignition, get better plugs. The better ignition eats up the stock plugs, that's why they say don't use it.
1 - 14 of 14 Posts
