1 - 4 of 4 Posts
I got a leak on my sensor in the tranny. I used some leak proof gasket sealant. Any other ideas? Thanks
Its really a plastic sensor I broke. I estimate its gonna be about $80 for a new sensor. But the sensor is good the housing is not sealing right since I broke it. Any ideas?
projected member
manual trans? big round plastic plug with wires coming out? replace it. called shift posistion switch. drain the fluid, but first make sure you can put the fluid back in by loosening the fill plug first. under the air box on the top of the trans is the plug. unbolt the switch and remove it. there's a small plastic plug thingee inside. slides out with needle nose pliers. then lube the o-ring on the new one before installing it
1 - 4 of 4 Posts
