I have 114,000 miles on my 02 Altima and I just found out my headgasket is blown. Apparently this is fairly common on the 02 Altima's? I still love the car though. Anyone else have this problem on their 02?
It's at the dealer getting fixed. Costing me $900.00.gtcompscientist said:Are you going to fix it, or is the engine ka-put?
Yes it sucks but I don't plan on getting rid of it. I have had zero problems with it before this!zerotwo-altima said:sucks ass. but i would pay the money to keep it running if it's an 02.
Several symptoms that at the time I didn't realize were the typical headgasket symptoms. White smoke coming from exhaust upon starting, rough start nearly every time I started her, antifreeze odor upon starting, loss of antifreeze, that is the first thing that started to happen was when I noticed my antifreeze kept getting low several months ago. This is still the best car ever!fr0mastaj said:how did you determine it was the head gasket? or..what lead you to notice i guess
The type of white smoke that I'm talking about out my exhaust is not the normal amount upon startup! I'm talking major smoke as if I've got a fire going on behind my Alty for a few seconds!zerotwo-altima said:loosing antifreeze may have been one sympton, but white smoke coming from your exhaust upon starting doesn't mean you have a blown head gasket, keep in mind your cat needs time to warm up and start working, in most cases (such as starting in the morning) it's just vapor from the moisture buildup. but if it didn't go away, then headgasket would've been my guess. but i'd have a compression test done if you haven't done so already.
You may have been right. My coworker just had his subaru headgasket replaced. Supposedly was a known common problem, according to whoever fixed his car.e_a_olson said:Hmm. Just traded in my Subaru because I suspected head gasket issues, and now I stumble into this thread. Thanks for the confidence builder guys!
All because you don't have a blown headgasket, right?RealDealSE-R said:i beat a 06 GTO 6 spd by 2.5 cars from a roll yesterday,and i raced him 4 times.i also raced from a dig and got him by only 1.5 cars..
he failed to say that the goat started off in 2nd geare_a_olson said:All because you don't have a blown headgasket, right?![]()
