1 - 10 of 10 Posts
3 have practicaly new tires ( Bridgestone Potenza's) All 4 rims are unscathed
And are the 2nd gen. (2k1) double din deck a direct plug and play? I wanted to buy one if it would work- but the the area it's in, hasn't been inventoried. I like the double din for the second gen. and if I had to go back to stock
then it wouldn't be so bad (my original deck's cass. only)
Retired
I'm not sure if they're a 'direct plug-n-play' but I bought a regular CD player (Pioneer) and a 'housing' at Best Buy. I'm not sure if they're 'housings', but they're the cases that hold the stereo in place when you wanna install into a Double Din space. They're not that expensive. You'll also need to buy a custom harness for the Nissan connector (also available at Best Buy). Use that to splice into the aftermarket deck's wires
You may see a picture of that 'housing' on my website
What I meant was the Factory 2k1 double-din. Thanks.
my b/f says hes pretty sure they are and if ur lookin to buy one Alby we have 1 we'll sell to u
if it'll work.I'll get back to you asap. If anyone wants the 2k1 headlights, they're there -intact. no tailghts tho (rearend/ hard hit)
hmmmm 2001 headlights my b/f might be interested in those ill have to get back to u too---how much u lookin for
Discussion Starter #7
the car is @ a salvage yard Brandie. I'll pm you the info.
Discussion Starter #9
Michael said:
Alby, did you save the little hamsters that powered the engine?? Tell me you did. please. :D ;)
:confused:
how've you been?? Hamsters?? Don't tell me your 240 already needs a motor.:D
1 - 10 of 10 Posts
