1 - 6 of 6 Posts
I am having a hell of a time trying to loosen the axle nut to remove the rotor, I have even stood on the breaker bar with no luck. Any suggestions
Thanks in advance
Legend
dismember
don't need to remove the nut. thread 2 bolts in the holes on the rotor. it'll free the rotor from the hub.
ChiaDog, Thanks!...So the rotor slides over the wheel studs, and the 4 studs are attached to the hub not the rotor?whats the nut holding on? I was curious about the jacking holes what they where there for...By chance, what size bolts? and metric or standard?
Legend
Import Tech.
Rotors are held on by the wheels ...and it is an 8mmx1.25 bolt .....
1 - 6 of 6 Posts
