Brake light only comes on when accelerating and turns off when I get up to speed
While you bumped a almost year old plus thread, did you check your brake fluid? The brake warning, trac, stability light all come on when the brake fluid is lowI'm having the same issue with both lights. Did you ever figure out the traction control light?
Almost 2 years later, I have no idea what I did to fix it, but it worked, because that issue is gone and I apparently never returned to this thread. Now my wife's 2005 has me pulling my hair out.While you bumped a almost year old plus thread, did you check your brake fluid? The brake warning, trac, stability light all come on when the brake fluid is low
Your light was on because your fluid was low. Pads were worn and this requires the pistons to move our farther and that requires fluid to take that space. Once you put new pads in the pistons were pushed in, the fluid was raised and the light went off.Almost 2 years later, I have no idea what I did to fix it, but it worked, because that issue is gone and I apparently never returned to this thread. Now my wife's 2005 has me pulling my hair out.
