I got one other question. How sure are we about the 2 degree timing advance.... I don't want any issues
I think that a question you have to ask yourself is why the Nissan engineers chose to set the ignition timing at 12 degrees BTDC on both the CVT and MT Altima models. How did they come up with that number, 12? Why didn’t Nissan add two degrees more timing, for a total of 14 degrees BTDC, like you can do with the Bully Dog tuner?
I don’t have a definitive answer, as I do not work for Nissan in their power plant R+D section. Nor do I work for Bully Dog.
I can only speculate that Nissan, after considerable testing, chose 12 degrees BTDC as the initial timing because any more than this amount of initial timing causes the activation of the knock sensor at higher rpm’s, and throttle openings, which sends a signal to the ECM to retard the timing until no spark knock is detected.
Which leads me directly to this question. How does one know that the knock sensor has detected a knocking vibration from the cylinder block, which is sensed as vibrational pressure? This pressure is converted into a voltage signal and sent to the ECM, which in turn sends the signal to retard the timing. Your ears may or may not be sensitive enough to detect the spark knock before the sensor detects it.
So, one could have his timing advanced 2 degrees or more by the BD tuner, but the knock sensor could retard the timing enough to prevent spark knock, and you would never be the wiser. No way for you to know for sure, unless your eyes are constantly glued to the monitor.
You say you don’t want any issues, and I agree with you.
Ask yourself one final question. Do you trust the engineers at Bully Dog more than you trust the engineers at Nissan?
Six months, or a year down the road, I would hate to be the one that had problems or issues.
