1 - 5 of 5 Posts
where the hell is it going
Check to see if the piston rings need to be replaced. Burning excess oil is one sign that those are starting to go. If so, put total seal piston rings in. Shouldn't be more than 300 installed.
H.N.I.C.
head gasket might be broken....
I'm The Orange Member
if uloose compresion is the piston rings and if its not is the valve seals. i had that problem and i blew the motor. the bad news are most mecaniks willrape u to fix this and will tell u to put a newer motor. so either u rebuildthe motor by changing internals with high performance parts or get another regular motor and after
a while u will have the sam problem by racing ad beating on it
Die Trying
Where in the hell can you get new piston riings put in for only $300? You're out of your damn mind!
1 - 5 of 5 Posts
