1 - 4 of 4 Posts
oki have these camber bolts from swaw, anyone have a close up pic of how to put them in, i have the sprint xs struts and they have to be in on monday, im putitng on new brakes and its goin in for an alignment. just need to know which way the bot should be facing and where the washer goes.
if you face the little lip on the washer towards the out side of the car, then it will increase camber which is probably what you want. positive camber is pretty rare. anyways, just put them in and adjust them to get the wheel as straight as you can, then go directly to an alignment shop and tell them you have camber bolts installed and they need to be adjusted.
ok here are some pictures, i think chuck said the "nub" goes facing the knuckle and the long peice hanging off faces the other way.
you see the nub in the second picture on the left side
the only thing is so the nub is the only thin touching the knuckle on that side??
also it goes on the side of the nut right now the side of the bolt.
1 - 4 of 4 Posts
