1 - 5 of 5 Posts
Evil Member
VEHICLE INFO:
YEAR 2000
MAKE Nissan
MODEL Altima SE (auto)
WEIGHT lbs.
GEAR RATIO
TIRE SIZE
TRANSMISSION INFO:
TYPE
INPUT SPLINE
TRANS-BRAKE Yes
No
FLEXPLATE SIZE
ENGINE INFO:
ENGINE SIZE cid
CARBURETOR
FUEL INJECTOR
CFM
CAM SHAFT
RPM RANGE
COMPRESSION RATIO
INTAKE MANIFOLD
ENGINE PLATE? Yes
No
THICKNESS
OTHER BOLT ONS or MODIFICATIONS
PERFORMANCE INFO:
30 FT.
E.T.
MPH
PEAK HP at
RPM
TORQUE ft.lbs
Hostile CAD designer
Try searching for the specs, or ask Shawn and Rev D. I'm sure they'd know, or could tell you where to find out
Evil Member
that helped a helluva lot shawn, thanks, but there are only a few more things i need to know, in case ya'll are wondering i'm trying to fill in the list thing for a torque converter. but the remaining info is:
transmission - input spline, flexplate size
engine - CFM, Cam Shaft, Intake Manifold
performance - 30 ft, e.t., mph
1 - 5 of 5 Posts
