1 - 16 of 16 Posts
What types of batteries do you use in your cars?? Mine is going pretty soon (probably won't start tomorrow) so i wanted to get a new one. I don't run many things off of the battery, just what ever the car needs, and a small amp, and PIAA fogs. Thats it. The alternator i will check later, but i'm fairly sure its good. My lights are only dim at idle, once going the lights are ok. Any suggestions as to battery type ie. optima, ac delco, etc.
I get whatever Sams Club carries cuz I find they're the cheapest. I've bought batteries from them for 5 cars over the past ~8 years and no problems yet. It's a major brand w/pretty high cca, but I can't recall the brand right now.
If you're gonna run some more electronics like a stereo system, maybe check out the Optima batteries. Quite a few of us here use them. The Red Top seems pretty popular.
Jay
MEMBER
i use 2 stinger sp-800 batterys, both under the hood, look on my home page for a pic
Discussion Starter · #6 ·
Thanks for the info, but i thought that if the car is at idle and the lights dim, then the car starts rolling and the lights get brighter, that the batter is at fault, cuz it can't hold the charge. I don't know, just going from what i hear. I'll get it checked either way, any other batteries out there on the market that are good??
Girl-Moderator
Interstate makes good batteries, also. I have an Optima redtop,
$100 at your local Costco, like Sam's Wholesale.
Discussion Starter · #9 ·
How much were the yellow and red tops?? and what is the real difference??
Ohyeah, and how many CCA does the altima need?? the battery i have says 650, but i've seen replacement batteries that are rated at 550. What do you suggest??
yeah, i want a bluetop battery, so the bluetop optima would make sense for me, but what's the diff between red, yellow, and blue? are they all for cars, or is just the red one made for our cars and the other colors for boats or whatnot...?
Batteries
I've been buying batteries from Sears for more years than I care to remember. Doesn't seem to matter which one I buy, they all last 3-4 years, even the cheap ones.
Interstate is supposed to make a good battery but I've never tried one.
Reppin Clarksvegas
i would want a bluetop simply for color purposes but i would like to know what the differences are in them.
Don't forget that if your battery isn't keeping a charge, the altenator is working a lot harder then it should.
Altimaluk, hope you made it home okay Monday!
Lates,
Drew
1 - 16 of 16 Posts
