1 - 5 of 5 Posts
I have a 2000 Altima GXE. Sometimes when I start it and put it in park or drive it dies. Idle seems to be pretty steady.
Also, I can push the gas pedal to the floor and it just barely will go and chugs a little. It eventually comes out of it. Any ideas what I should check? thanks in advance.
MAF sensor could be dirty or no longer working, or could be a vacuum leak. Can you scan the computer and see if there is any check engine codes.
I finally cleaned MAF sensor with the cleaner they sell at the auto parts store. It has been even worse since then. Tonight it lost all power and would chug badly. I wasn't sure if it was ever going to go again. Then it acts normal again for a while. Is this a sure sign of a bad MAF sensor? Why would cleaning it make it worse? Thanks in advance.
2010 2.5 SL
How's your radiator fluid? When my former car did this, it was due to low fluid and a cracked reservoir.
My 2001 GXE does this exact same thing on occasion (only if it sits outside and there is a lot of moisture in the air or if it is cold). Try letting your car warm up for 5min or so and try shifting it in R or D again, it helps with mine if it acts up. Service manual calls out the idle speed as the most probable cause. I have also read that it could be the idle control valve or air temp being bad.
1 - 5 of 5 Posts
