1 - 12 of 12 Posts
H.N.I.C.
ok, some of u may hav read my "fudged up night" post in OT....
i think something is wrong with the fuel system
i recently changed my fuel filter 'cause my car was choking a bit..
it helped out alot, but it still didn't seem to run quite right...
i hit a patch of constrution work on the road kinda hard n the alty cut off....
it would start, but it would sputter then die, like it wasn't bein' fed enough gas
i doubt it's electrical, but i'm open to ideas
my distributor looks fine, n the symptoms were a lil' different wen i had problems with that...
maybe my fuse for the fuel pump has a glitch since i didn't pull it out with the proper tool but instead with a screwdriver, i don't know....
first thing to do is to make sure you have gas! Sounds silly, but it could just be an oversight!
I would check the fuse for the gas pump, then check the connections on the fuel filter and make sure the hoses are hooked up right. Clogged cylinders maybe?
H.N.I.C.
has a quarter of a tank...
i think all the hoses were in, 'cause i didn't smell any gas...
it was too dark (12:30-1:30am) to really check it out..
i didn't even bother going to check it out today
i didn't want to even deal with the car..
i'll see about it tomorrow...
my engine light stays on 85% of the time, i'll check it....
H.N.I.C.
well, the fuse is ok...
i guess i'm gonna hav to take out the back seat to check the fuel pump....
anyone else got any thoughts??
i made sure the vacuum between the throttle body n the intake filter was sealed up good....
oh, n the screw that allows me to see the flashing check engine light and reset the ECU is broken :(
isn't there a light attatchment or sumthin' i can hook up to see the codes??
H.N.I.C.
Discussion Starter #7
djsassan said:
bro, I am sorry, but you have definitely got me stumped.
U'RE stumped
i'm lookin' through all the things that could be wrong in the haynes manual.....
but i don't hav a pressure gauge or a volt meter to check everything
Shadetree Mechanic
Take it to Nissan. Nobody knows em like they do:D
'96 Max SE loaded
they may be expensive, but theyll fix your problem, and youll probly savin money in the long run lettin the right people fix you car instead of havin shitty mechanics work on it and it tear up within the next few months
1 - 12 of 12 Posts
