1 - 14 of 14 Posts
My car is bone stock...
Discussion Starter · #4 ·
Everything looks OK. I took the car into the shop the other day and they checked it on the computer, the code 21 came up? Anyhow, I had the ignition coil from before and next to the 21 on the screen it said ignition, so I figured that was it. Could it be the distributor housing?
Nipponese
OK you're right, 21 or 0201 is a error code for ignition signal circuit according to the factory service manual. Check items include; Harness or connectors, Power transistor unit, Camshaft position sensor, and Camshaft position sensor circuit.
BTW, thanks SLCentral.:D
Discussion Starter · #6 ·
Oringinally posted by poisonfist
Thanks for the help...My bf put the coil in, so I have no clue where to start looking for those parts you just mentioned. Is it near the coil? :p
Damn! I Drive a Civic
i had this problem when my tranny was messin upp....
i just threw it in park turn of car start back up go thew every grear then turn back off turn back on and try to get it to work
SOmething like this just happened to me just a couple of weeks ago. I put in a fuel injector and system cleaner and drove it around a bit. The next time I drove it again the car had less of a problem reving. I bought it from R&S Strauss for $2.50 with a $2.00 rebate.
1 - 14 of 14 Posts
