1 - 9 of 9 Posts
My gf went to the dealer for her 60k tune up, they said that she also needed to change her Dist cap/rotor, and her Fan belt. She refused on both, I told her I could do her cap/rotor, but I was wondering, what is the fan belt?? I know that theres the alternator/accs belt, prolly an A.C. belt, and a power steering belt maybe? Are they tryin to rip her, or is there really a fan belt, also, how hard is it to change the AC and the alt/acc belt? tons of labor involved? or is it a simple belt tensioner you just loosen, then pop out both belts, thanx
Sam
oh, and yes, I haven' bought the haynes manual yet, but will soon...:p
clean freak
they were probably just referring to the main serpentine belt (aka fan belt) although in our cars the fan is run by the electrical system. Older engines (like a big block chevy) used to have their fans run by a belt, hence the name "fan belt."
At 60k, you should replace the two belts on the car just a preventive maintenance measure.
Am I still a NOOB?
Fan belt is easy as hell, all you need to do is loosen the alternator belt tensioner bolt, and the belt comes loose, take it off, get a new one, put it on, tension it to specs or just tighten it and you should be set.
Import Tech.
See , thats the difference between a dealer 60K and a good shops 60K , the Cap and Rotor should have been included in the 60 K !!!!! Cap , Rotor , plugs , air filter and fuel filter are required on the 60 K , as well as transmission fluid , coolant change , brake check and flush , oil change, and general checkover ...!!! As for the "Fan Belt " ... If they called it a Fan belt I would talk to the Manager , and have them show you which fan the belt drives , since they have no fan to drive , the belts ( there are 2 of them ) should be done around 60K , at that time they get cracked and should be replaced , stop going to the dealer for service , find a good independent repair shop !!!!!
Discussion Starter #8
hahah I know~!, I yelled at my gf for takin it to the dealer, especialyl since I can do most of that stuff in my backyard.
I dont' really trust anyone around here (queens ny) but I am gonna have to find a trustable mech. for big jobs eventually tho....but thanx guys~! I'll prolly get to the belts and cap/rotor this or next weekend:D
sam
Erect Member
when you do that alt belt, lemme know if you have a problem with the belt only gettin "so" tight. im having a problem KEEPING my belt tight. the alternator will only allow so much tension on my belt so im curious if its just mine or a common problem. thanks man.
1 - 9 of 9 Posts
