1 - 3 of 3 Posts
Ok my girlfriend has a 93 altima SE. it was having a problem where it would stall out. I checked the ECU and it said it was throwing a code 11. I replaced the dist. and everything is great. the ecu says its throwing a code 55, which is normal operation, but it keeps popping up. I cleared the ECU the way the manual said to. the check engine light still throws code 55 like every other day. How to I get the CEL to stop throwing it?
55 is normal operation and wouldn't be thrown.
This means that there is another problem or you are not reading the codes correctly.
Find the real problem is your only solution!
1 - 3 of 3 Posts
